Opening a clean out
Opening a clean out
~30 years old.
What are the chances those screws come with just a flat head screwdriver?
What are the chances it doesn't leak when I put it back on?
Temporarily Suspended
Spray it with PB Blaster or your country's equivalent. It shouldn't leak when you close it. There isn't any pressure unless there is a stoppage. Why do you need to open it?
I'd soak it with PB blaster for awhile. Use a very high quality screw driver of the right size (blade should fit snugly, no slop). Gingerly tap it with a hammer as you try to loosen screws.
This is a drain or sewer cleanout, right?
Resealing should not be problem. If need be a silicon bead or Loctite Red form-a- gasket will work.
An impact screw driver is what I'be using.
https://www.zoro.com/klein-tools-scr...20/i/G1690945/
As you tap the end of the screwdriver with a hammer it turns the screw.
I used to use this all the time on the soft Phillips head screws on motorcycles.
