One side of double sink backing up
Old 04-01-16, 01:57 PM
R
In the pic there is silver piping running to the disposer on the left side sink. The white piping runs up to a sink that has a dish dryer in it. When I run water down the left hand sink the right hand sink piping will back up and gurgle. I removed the white piping down to the elbow that fits into the main line and ran a 20' auger down it. Still, when I run water in the left sink, the right one backs up. Any ideas on what might be going on?
Thanks!
Old 04-01-16, 08:25 PM
Received 3,409 Upvotes on 3,059 Posts
Although you ran a snake thru the drain line..... the problem is below the visible point in the picture.
If the pipe runs horizontal to the floor to a main stack..... the problem would probably be right at the stack.
Old 04-01-16, 08:41 PM
XSleeper's Avatar
Received 1,696 Upvotes on 1,522 Posts
Not part of the clogging problem, but those s-traps don't meet today's code. Sounds like you need to do more augering.
Old 04-02-16, 10:54 AM
R
I augered it out 3 more times and that seems to have done the trick, thanks!
