How to connect water line for humidifier
Old 04-02-16, 08:41 AM
I'm installing a humidifier. It came with a saddle valve but I don't have cooper pipes in my home.
I have a small port right after my main shut off. It's about 1/8 inch with a twist off cap. The copper line that came with my humidifier install kit is too large for this but can I get an adapter and use this small port?
Thanks in advance!
It looks like this: gstatic.com/images
Old 04-02-16, 11:21 AM
Handyone's Avatar
I would install a valve this way:
- Cut the pipe at a good location for the valve
- Install a sharkbite tee
- From the tee you have the option to install the valve there or run pipe off the tee
Old 04-02-16, 01:01 PM
Received 99 Votes on 87 Posts
No you can not and should not connect the line to that boiler drain.
If it's not copper what is it?
Old 04-02-16, 05:00 PM
Thank you!
I didn't realize I could post pictures in here. This is what mine looks like.
Old 04-03-16, 11:26 AM
Anyone? Can I use that little nub to connect my humidifier? If not can I connect the saddle valve to that little bit of cooper there before it turns into pex?
Old 04-03-16, 11:42 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
No. That is why every one is telling you the correct way to do it. (Only boiler drain I have dealt with wasn't even pipe thread.)
Saddle valves are not recommended because they clog easily.
Old 04-03-16, 12:06 PM
Received 1,476 Votes on 1,364 Posts
That little nub (cap) on the valve is a drain port for draining the water out of the line when servicing it. That needs to stay removable.
I know in many states the use of a saddle valve is now against code. They are an easy and unreliable way to connect a humidifier to a supply line.
This kit features sharkbite fittings which don't require any soldering to copper.
SharkBite Ice Maker Installation Kit-25024 - The Home Depot
Since you're working with PEX there you need only make a single cut, deburr the pipe and install the kit.
great minds think alike two responses for the price of one.
Old 04-04-16, 10:05 AM
Thank you all so very much!
I really appreciate the help and pictures!
