Plumbing a kitchen double sink, with dishwasher and disposal
I have a double kitchen sink with disposal and dishwasher. I plan on connecting the outlet from the dishwasher to the inlet on the disposal.
i have 2" ABS coming out from the floor.
The kitchen sink is on a peninsula.
The current design is 2 sanitary tee's stacked one on top of each other, each with with a trap adapter for each respecting trap from each sink drain.
Is this the best design?
It currently vents out the top of the sanitary tee into a 1 1/2 roof stack.
everywhere i look the disposal side has its own trap. Each goes into a vertical stack that i mentioned consisting of two sanitary tee's one on top of each other.
Im telling you what code is as I know it..
You can hook it up anyway you want.. Its your house..
I just answered your question is all..
my current waste line goes through the floor. It is 2" ABS. I plan on cutting it off at the bottom and re-doing to fit my new deeper sink. I need a design that ends with going straight into the floor, and also incorporate a vent line before it goes to the ground.
Right OK, so 5 would literally be a sanitary tee, with a 2" bottom, 1 1/2" for the trap side, and then 1 1/2" on the top which leads to the vent, correct? I've seen this model a bunch online, but when i look around my city at both existing and NEW construction, it seems that EVERYONE has a 2 trap system. They have two inlets into the wall, one on top of the other.
I've seen this diagram before, but the feedback that i've heard is that the drainage isn't very good, this is why i have been seeking a two trap system.
Garbage Disposal Plumbing
Below is a sink I hooked up. I like to hook up all sinks like this if at all possible.
Notice the disposer elbow goes down into a baffle tee, which is also where the other bowl ties in.
Can anyone think of why one would use a two drain/trap design vs the singular approach that has been given many times? In my city, all the new construction seems to use a two drain (vertical stack) design
IF the two drains are installed at the correct height and at the correct angle, then connecting the plumbing would be easier. This never happens to me when I walk in and just simply connect two traps. It usually turns into a pain.
The picture I posted is ideal to me. If I see this trap set-up, I know I'm going to have a good day.
I want to make this easy on you.
Some municipalities require that a commercial or restaurant garbage disposal have its own trap. This is never a requirement in residential. 2 traps is just a needless congestion when one will do.
Most places in the US likely follow the IPC 2012 as the basis for their local code... 1002.1 Fixture traps. Exception 2.
You never said where you are located in Missouri. Maybe you've got an inpector that has his head in the sand... or maybe you're in an area where there is no code and it's a free for all.
2 san tees on top of each other is a wet vent.. wet vents have not been allowed for sometime..
I cant fathom that you see this in new construction..
Show me a pic if you can...
