What type of metal is this toilet drainpipe connecting to the cast iron stack?
In the process of working on a new toilet location and came across this. I was expecting cast iron, which I would have cut with a chain crush/cutter. But this might be worth just cutting and pulling out, yes?
I'm sorry that the picture is rotated 90 degrees. On my computer and phone it's in the correct orientation. Something must have been lost when uploading it to this site.
Thank you, but what does "set" mean?
And because I want to cut it, or take it out so I can eventually get it connected to a new black plastic pipe, what would I do?
Lead was usually set into cast iron by shoving an oakum braid around the perimeter then molten lead was poured into the joint. In your case, this was obviously done in the upright position before the cast iron was assembled. If you want to remove it, you will likely be replacing the cast iron hub as well.
So, would I be able to use a torch and melt that seal?
In reading about these seals, here is one site that described a process:
https://www.summet.com/blog/2012/09/...omment-page-1/
Here is teaching video
https://youtu.be/NednRKyy2Dg
Another on Youtube showed how to install and remove with a oxy-acetyline torch, which I have. And since it's all exposed and not cramped, I think I could use a torch.
Actually there's a brass ferule caulked (leaded) into the hub and the lead bend is 'wiped' onto that ferule. The son of the plumber that put it in is an old man by now. You should definitely replace that lead bend.
Some folks will clean the lead off of the ferule and couple onto it. Personally I don't think that's as good a job as cleaning out the hub (you can drill the lead with a 1/4" bit) and installing a new cast-iron closet bend. You can use rubber donuts to install the new closet bend but they can take a /lot/ of force to push in. Dish soap helps a little.
I'm an old guy and I would just pour lead, but a donut (if you can get it in) will work just fine.
You said you were moving the toilet. You will probably be removing the cast iron hub anyway. There is no point in melting the lead out. Cut it off with a sawzall and replace the hub. Or cut it off with a sawzall and use a fernco fitting on what's left of it.
