Plastic gas pipe? Indoors?
Old 05-24-16, 10:49 AM
G
I was discussing home DIY with a neighbor and he told me he used yellow plastic gas line in his basement. Easier to get around obstacles and way cheaper than CSST flex pipe. No--he wasn't confusing the 2.
I've never heard of the stuff. Trying to Google it I mostly came up with references to the plastic pipe the utility uses up to your meter. It's OK for indoor use now?
Old 05-24-16, 11:07 AM
C
Sure hope he doesn't ever have a small fire...talk about feeding the flames
Old 05-25-16, 10:04 AM
G
So you're saying it's improper and plastic gas line is not allowed indoors?
Old 05-25-16, 10:22 AM
C
PE Plastic gas line is only approved for underground use.
Old 05-25-16, 11:35 AM
Z
Yeah, I don't know of any plastic gas piping that's approved for indoor use anywhere. As far as I know, it's only steel pipe, CSST, or soft copper in certain locales that's allowed for NG or LP piping.
Old 05-25-16, 12:52 PM
C
And if your friend needs any convincing to change it out; should he have a fire, the fire department will find it and no way will his insurance co. pay the claim.
Old 05-26-16, 10:33 AM
G
I pointedly asked him if he was talking about corrugated metal (CSST) and he insisted no--it is all plastic. Said you're supposed to have special training to work with the stuff--but that also applies to CSST, I think.
I think he's mistaking the yellow plastic jacket on CSST for yellow PE tubing, or maybe we just weren't on the same page at all.
Before I posted my question I tried to Google some references to PE being used indoors and I did get some hits claiming it's growing in popularity. HOWEVER...have you ever tried to ascertain the "where & when" an internet article is about?
Old 05-26-16, 10:57 AM
Z
Bigfoot is real, the internet says so, it must be true!
I'm sure there are some manufacturers working on plastic gas piping, it would make installation much easier. But I wouldn't want to be the one who accidentally puts a nail through it or hit it hard while moving stuff in an unfinished basement. A nail through a PEX water pipe or loose PEX connection will make quite a mess. Consider the same with a gas pipe...
Old 05-27-16, 07:46 AM
G
Agreed...however...CSST is the thickness of 2 sheets of paper and won't stop a nail either. How long does that stuff hold up in a fire?
Not arguing--I just sometimes wonder why some things get approved that are obviously inferior to the "old" materials.
Old 05-27-16, 07:55 AM
G
...which all had me thinking about how much things are going to change as technology like 3D printers evolve. Some day probably real soon a big gantry like the rolling platform NASA uses for launches will roll down your street and squat over a hole in the ground and poop out a complete house in a few hours. It's already being done on a smaller scale. Some codes will need to change. Maybe for the worse.
Old 05-27-16, 08:07 AM
Handyone's Avatar
I'm hardheaded I find it hard to believe the DIY guy was not confusing the CSST for plastic.
I think, or I would hope, he installed CSST and doesn't know it.
As far as the price I would spend more for the CSST, it's easier to run and you have less joints.
Less joints = less chance of a leak.
Old 05-27-16, 09:23 AM
E
In my country plastic jacketed steel like this is incredibly popular with DIYers and plumbers alike because it can be installed without threaded joints. I have no idea if something similar exists in the US and regardless, its not 100% plastic anyway although its kind of easy to confuse at a glance.
Old 05-27-16, 10:05 AM
G
Seems like a smart product, Esand1. I'm a little surprised the solvent isn't colored.
Old 05-27-16, 10:16 AM
E
That's because there isn't any solvent to see. The joints are fused by heating the pieces during installation
