Gas meter connection and pressure
Old 07-13-16, 06:13 PM
K
I am wondering how to connect the gas line from the house to the meter. Is there a special fitting? I am looking at increasing the pipe from the meter to the house from 3/4" to one inch to accommodate some new appliances that require one inch. Also, will my current meter be sufficient? thanks
Name:  gas meter 2.jpg
Last edited by ray2047; 07-13-16 at 06:25 PM. Reason: Cropped white space and enlarged inage.
Old 07-13-16, 07:42 PM
lawrosa's Avatar
Super Moderator
Easiest will be to change the elbow that turns to the home to a 1 x 3/4 ellbow. Then run 1" into the home accordingly.
Dont know the CF of your meter and your btu load in the home to guide you.. Just call gas company...
I do this for a living...I install whole hose generators...
Also IMO best to leave a tee outside with a cap for future expansion for gen, or pool heater possibly.. Grill or fire pit...?
Old 07-13-16, 10:52 PM
K
The line coming out of the meter towards the house is a 1" nipple -> 1"x3/4" elbow -> 3/4" pipe in the rest of the house -> 1/2" to each appliance.
lawrosa, do you mean the line can be 3/4" out of the meter and upsize to 1" down the line? Wouldn't the line need to be 1" straight out of the meter? I'm a little confused on how gas pressure works. For example the 3/4" that comes out of the ground and feeds the meter--shouldn't that be bigger than what goes into the house? similar to water supply lines getting smaller the closer you get to each fixture.
Old 07-14-16, 01:10 AM
F
Not necessarily. The supply is at a significantly higher pressure, which is reduced by the pressure regulator immediately before the meter inlet. Depending on the supply pressure (most likely somewhere between 2 and 25 psi) that 3/4 inch incoming pipe may be able to supply ten times the amount of gas your house requires.
If you currently have a reducing elbow simply swap it for a regular 1-inch elbow.
