Connecting copper pipe to galvanized pipe
Old 08-10-16, 12:42 PM
L
I have a 1/2 copper npt female connector at the end of my pipe run. I want to connect an hose bibb. Can I use galvanized npt pipe and thread it into the copper?
Old 08-10-16, 12:54 PM
XSleeper's Avatar
Received 1,812 Upvotes on 1,629 Posts
IMO, it would be better to install a dielectric union between the two.
Old 08-10-16, 01:38 PM
Norm201's Avatar
Received 693 Upvotes on 616 Posts
It would be better to use a PVC pipe with threaded adapters attached to accommodate the copper and the hose bib.
Old 08-10-16, 06:28 PM
Tolyn Ironhand's Avatar
Received 784 Upvotes on 664 Posts
As the others have mentioned you need to have some type of separation between the dissimilar metals other they will corrode between them. The further the separation the better. A dielectric union the give some separation but adding dielectric nipple in addition to the union is better. Here is why:
Name:  dilectric nipple.jpg
Source: Home Care Myths Busted! | The Family Handyman
Old 08-10-16, 06:39 PM
Norm201's Avatar
I was thinking more along these lines.
Use two of these with a piece if PVC between them. all you need to do is glue it.
Old 08-11-16, 10:02 AM
Z
Received 400 Upvotes on 356 Posts
Like others have said, I would stay away from galvanized pipe completely. Depending on your water chemistry, the nipple could start corroding in months, or it may last years. Regardless, there are better answers:
You can use copper (male threaded to 1/2" copper to female threaded) (my choice)
You can use PVC with the same setup
You can use a brass nipple if it's just a short nipple you need
