Water heater connections
Just bought a house that has a reasonably new gas water heater plumbed with PEX pipe. No problem, I need to replace the first 18" with copper... or I thought it wouldn't be an issue.
It seems the female -> PEX couplers that were installed were tightened by someone with superhuman strength. I cut the PEX and now I can not get the fitting to budge at all from the water heater. I've used a 12" pipe wrench and the hot will not budge. I was able to unscrew the cold nipple - which turned out to be the whole dip tube.
So what do I do now? I can replace the dip tube (that looks like this). But the hot side I can't do anything with. I've considered a hacksaw or sawzall, but I think it'll be a pain to get through the brass (?) PEX connection and will likely damage the threads. Other option is a bigger wrench, but I don't want to break anything - and I'm not sure how to get enough leverage on the tank.
Any suggestions? This is a new one for me!
-Mike
-Mike
Get a bigger wrench or put a pipe over the handle of your 12" wrench. It helps if the heater is full to hold it in place so you can have both hands free to pull on the wrench. If that doesn't work then I'd try hitting it with a torch then use the long wrench on it.
