Washing Machine Drain Hose Routing
Old 01-04-17, 09:39 AM
K
For the drain hose coming out of the back of the washer does it need a loop or anything? Or can it be in the shape of a candy cane where it comes straight up back of the washer (from where it's hooked in via factory) then curve a 180 directly into the standpipe?
Got a new washer and the hose is way too long so wanting to cut it but want to make sure I don't mess anything up. Right now it's a jumbled mess behind the washer.
Old 01-04-17, 10:00 AM
pugsl's Avatar
Received 77 Upvotes on 70 Posts
As long as you don't put a pinch into it you can cut it. The top of the drain must be above the water level in washer.
Old 01-04-17, 10:16 AM
K
Thanks! Candy cane it is.
Hate having a wadded up mess back there between the drain hose and the water line hoses that always seem to want to curl up in a twist.
