PVC to Cast Iron Toilet drain... which Fernco?
I had a broken toilet flange. I cut off the old lead drain pipe, leaving a 1.5" stub before the cast iron fitting. How should I connect the new PVC pipe? I tried to link pics of the possible solutions.
- Use a shielded 4" Fernco coupling to a PVC 4" to 3" reducer, then 3" PVC pipe. Pic#2
- Pass 3" PVC through a Fernco 3" to 4" reducing coupling, with PVC extending deeper into the Cast Iron. Pic#3
- Your incredible solution
Based on the 4" pipe to street elbow to flange being too high, I plan to reduce the pipe size to 3"... see below. I've also been told that 3" is better because it flushes at a higher velocity.
The distance from the top of the stub to the top of the rafter is 1.75". The rise for the 4" PVC Street elbow is 3.25". 3.25 - 1.75 = 1.5" above the rafter.
I planned to use 0.75" plywood + 0.5" backboard = 1.25"
That leaves me with a street elbow 0.25" above the backboard before I attach the flange. As I understand it, the flange should sit flush with the backboard, not above it. Am I wrong - should the flange sit atop the level of the floor tile? How would I screw down the flange if it is sitting on the tile?
