Kitchen sink leaking from base of spout (Delta).
When i turn either faucet on, water leaks out of the middle piece, where it screws together. I unscrewed it and pulled a cartridge type of deal out. Will replacing it stop the leak? If so, i guess i will have to go to a plumbing supply store, because i couldn't find anything that looks like that at Home Depot.
Here is where the leak is coming from:
And here is what i pulled out:
If you contact Delta customer service with these pictures and the problem, they will most likely send you the parts you need to rectify it free of charge. Worth a shot.
You need diverter RP63135.
Here's a view from HD, it shows not carried in stock:
Delta Kitchen Faucet Diverter Assembly-RP63135 - The Home Depot
