How to stop a leak of pvc pipe threaded to plastic
Old 04-15-17, 05:22 PM
R
I threaded some pvc pipe onto a plastic piece. It's an adapter to use a saltwater system for my pool. I used oatey great white and pliers to tighten as much as I can. I can't loosen it to try again. Any product or idea that I can use so that drip stops. I could undo the pool hoses to stop the flow of water if a product requires setting. No idea why there is a picture of my attic. Also not sure why the picture is rotated a bit but you can see the drip ThanksName:  IMG_0056.jpg
Old 04-15-17, 05:56 PM
Your pictures do not show the leak.
I can not think of a single reason to use "plyers" on a pipe fitting.
Old 04-15-17, 06:10 PM
R
The picture needs to be rotated but if you look dead center you can see a drop of water. ignore the attic pic haha. Is there something to spray or put on the leak to stop it?
Old 04-15-17, 07:24 PM
chandler's Avatar
Is the clear pipe and the pvc fitting the same size and thread pitch?
Old 04-15-17, 07:35 PM
lawrosa's Avatar
Super Moderator
Removed .
Old 04-16-17, 04:31 AM
Marq1's Avatar
Unfortunately there isn't anything you can do from the outside, the joint needs to come apart and resealed.
Looks like sufficient sealant was used but might have been a distortion in the pipe thread.
I'd try teflon tape and sealant.
Old 04-16-17, 05:02 AM
ray2047's Avatar
Old 04-16-17, 06:54 AM
Norm201's Avatar
Old 04-16-17, 12:07 PM
W
Tools
The OP used pliers, which are very frequently used in the plumbing trade.
Old 04-16-17, 01:26 PM
Norm201's Avatar
A water pump pliers is very common among plumbing tools but not your standard slip joint. But then again one uses what's within arms reach.
