Which tailpiece?
Old 05-08-17, 09:04 PM
B
Which tailpiece?
This forum has already been a great help for my project, so thank you all.
I want to make sure I get this tub drain right the first time. Can someone tell me the proper way to connect a 1.5" tee to my trap in slab?
Old 05-09-17, 12:03 AM
lawrosa's Avatar
Super Moderator
Received 78 Upvotes on 70 Posts
Old 05-11-17, 09:53 PM
B
Here's a pic. Still not sure how an adapter works on this.
Old 05-12-17, 03:54 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Ouch, your 2" trap has been reduced considerably and will probably all need changing out to the lateral at the lower right of your picture. Unless it can be detached at the entrance to the trap.
Old 05-12-17, 08:05 AM
B
Sorry here's a better pic
Is that threaded 1.5" piece in the trap normal? Is there an adapter to get from the that to 1.5" dwv? Thanks guys
Old 05-12-17, 09:53 AM
lawrosa's Avatar
Super Moderator
Why dont you use a standard waste and overflow? It uses the standard threaded tail piece..
[ATTACH=CONFIG]80664[/ATTACH]
Old 05-12-17, 09:58 AM
lawrosa's Avatar
Super Moderator
Otherwise you need to glue a trap adapter to the bottom of your tee and use /cut a small piece of tubular pipe/tailpiece to fit between trap and tee.
Old 05-12-17, 01:10 PM
B
Thanks a lot! The assembly we needed to match the other trim was only available in this pvc set or that one which was too expensive.
Old 05-12-17, 04:13 PM
chandler's Avatar
I wasn't aware it was a tub, so using the assembly Mike mentioned makes better sense than building one. You already have the adapter in place. It just looked like a pipe stub in the first picture.
Old 05-12-17, 10:31 PM
lawrosa's Avatar
Super Moderator
You can get overflows in any trim. plastic, brass, etc... chrome, nickle, pewter, bronze, etc...
But if thats what you want to do glue a trap adapter to bottom of tee. Stick tubular pipe/tailpiece cut to size between the two to trap with nuts and washers and be done with it..
Old 05-12-17, 10:34 PM
lawrosa's Avatar
Super Moderator
30 bucks tubular is the way to go instead of hodge podge...
[ATTACH=CONFIG]80695[/ATTACH]
Old 05-16-17, 08:37 PM
B
Sorry that first picture was misleading. I returned the unit and gonna make the one with a built in tailpiece fit. Thanks for all your help, now have to cram this tub in there and finish it.
