Clothes Washer signals "no water"
Received 0 Votes
two things happening recently :
1) When the washer is filling and someone flushes a toilet - the washer stops filling and signals "no water"
2) When the bathroom sink is running - the toilet runs. Flapper is fine - new flapper and only time the toilet runs when it is not supposed to - is when the sink is turned on
Is this something I can fix myself or do I need to call in a pro?
Thanks
Thanks
In sounds like you have low water pressure, perhaps due to an obstruction. Do you have a whole house water filter or water softener that might need servicing? Also, check to make sure your water shut off valve(s) are fully open.
When you run the water in a sink or tub, does the flow and pressure seem normal?
Is this a well system or city water?
What type of plumbing? Galvanized, copper, plastic?
Received 0 Votes
We do have a water softener - and I don't think it has been serviced in a while - did not think they had to be serviced!
When we run water - sometimes the pressure is fine and many times it seems like the pressure is lacking. It is not a well - it is city water. I believe the plumbing is all copper.
Try putting the softener in bypass mode for a day or two. There should be a bypass valve behind the softener. You will have hard water for that period, but it will rule out the softener (or rule it in) as the problem.
Take hose off back of washer and see how the water runs there. Put hose in washer or a bucket. Next take screen out of back of washer valve ( it is in the end and comes out fairly easy) clean screen and put it back in, Only need to do cold water.
