Teflon tape or thread sealer, and pressure question
Old 07-21-17, 05:03 AM
G
I'm about to replace the pressure relief valve by the bladder tank. Will teflon tape suffice, or should I use thread sealer...which is what was used previously?
Also, the water conditioning guy was here a while back and he boosted the pressure at the pressure switch from ~25-45 to ~45-65. And hence, the leaking relief valve...the pressure was going up to ~72 on the gauge, which is new. I reduced the pressure to ~40-60.
I'll check the air pressure at the bladder after I drain the water, and adjust the pressure for a 40-60, i.e., ~38. This is a system with a deep well.
Is this a safe strategy?
Old 07-21-17, 06:23 AM
Teflon tape should be fine at 60 PSI
Old 07-21-17, 08:08 AM
W
Received 17 Votes on 16 Posts
Thread Sealer
What kind of pipe and fittings need to be sealed?
Old 07-21-17, 08:49 AM
G
Ti's a standard relief valve that tee's off the line from the bladder tank to feed the house. It's brass, 1/2 in male threads into galvanized 1/2 in female threads in pipe.
Old 07-21-17, 08:59 AM
lawrosa's Avatar
Super Moderator
Received 60 Votes on 52 Posts
one or two turns of tape,then add some paste onto that. So answer? Use both....
Old 07-21-17, 06:39 PM
Handyone's Avatar
I do the same as Mike, tape and Teflon paste over the tape. No leaks and no callbacks, which is what I like.
Old 07-22-17, 07:29 AM
G
Thanks for the responses. Got the sealer yesterday.
HTML code is On
