Gas Dryer Pipe Help
Old 08-16-17, 01:23 PM
T
Gas Dryer Pipe Help
We just moved in to a rental with a 3/8" gas valve for the dryer. The dryer we bought is 1/2" input. The connector we bought was 1/2" on both ends and we bought a converter to the 3/8" end. Had our electric/gas company come to check and there was a huge leak. He recommended NOT using a connector on the valve and that was the cause of the leak. I went to Home Depot and they do not sell/make connectors with different size ends. What do we do now????
Old 08-16-17, 01:33 PM
Since it's a rental, you're supposed to call the owner. By code, it should be re-piped.
Old 08-16-17, 02:09 PM
T
Thanks! Do you think the valve needs to be replaced?
Old 08-16-17, 07:05 PM
Received 3,415 Upvotes on 3,063 Posts
The gas demand is very low in a dryer so the 3/8" valve is fine. Get a 3/8" to 3/8" gas flex line with an adapter to go to 1/2" pipe.
You probably got a flare fitting adapter..... not one for a flex line. There is a major difference. The adapters should come right with the flex line.
As always..... in a rental situation.... be sure the owner is aware of what you are doing.
Old 08-16-17, 09:59 PM
T
Great. Thank you so much!
Old 08-17-17, 09:27 AM
Handyone's Avatar
Here's a picture of the 1/2" adapter Pete referred to. Almost all gas appliances have a female 1/2" pipe thread inlet regardless of the size of the flex line.
