PVC fitting not fitting
Old 08-27-17, 03:46 PM
D
I'm replacing a bathtub with a walk in shower. I have to move the drain. I cut the old drain out after the trap. Here's the issue...the drain pipe is 2" but 2" fitting will not fit, the drain pipe seems slightly too large. Is it possible it's no longer round but slightly oval? Is that a thing? All the old fittings are 2". Can this be fixed without serious work?
Old 08-27-17, 03:52 PM
Received 4,145 Upvotes on 3,722 Posts
Welcome to the forums.
Is this pipe PVC..... ABS ?
A 2" fitting is a 2" fitting. You should be able to see if the pipe is not round.
Old 08-27-17, 03:54 PM
How about a rubber coupling with clamps?
Old 08-27-17, 03:59 PM
D
PVC. It's hard to tell from the angle I'm looking from. But I don't what else it could be.
Old 08-27-17, 04:01 PM
If the pipe wasn't cut cleanly it could have burrs on it making the coupler tight.
Old 08-27-17, 04:02 PM
D
I thought about a rubber coupling with clamps but don't know how long it would last under the foundation and all.
Old 08-27-17, 04:07 PM
Are we talking about a crawl space or buried underground?
Old 08-27-17, 05:12 PM
D
Buried underground. Under the foundation.
Old 08-28-17, 01:43 AM
Marq1's Avatar
Received 1,211 Upvotes on 1,099 Posts
No coupling style connections under a slab, bad idea!
Some pictures would help. but a unless you are mixing up different types of fittings they should fit!
