brass compression fitting to cpvc
Found a double shut off that need to supply two 3/8 od supplies and has a 1/2 compression fitting, can that brass compression fitting be attached to cpvc pipe? I would think so but just want to make sure.
Always appreciate the help.
Well, since you haven't gotten any answers (and may have already figured it out on your own) I'll just say that any compression double-stop that I've ever seen has been for copper. It wouldn't fit on CPVC. Not to say that such a comp stop doesn't exist, just I've never seen one.
A Brasscraft angle stop for CPVC glues onto the water supply and uses a rubber washer, like so:
They probably make a double,
You can use a standard angle stop and a 'splitter' to connect two fixtures.
Something like this:
https://www.amazon.com/dp/B007PT0YXW
