Hot water trickle from faucet
Downstairs sink duel hot /cold taps..worked fine til about 6 months ago...gradually the hot water volume began to slow...and now it trickles after about 20 seconds, with tap now only turning about half way around. Help.
Welcome to the forums.
A clogged filter screen on the aerator will cause low water flow but usually on both the hot and cold faucets.
City water or well ?
Older faucet ?
Could be a problem cartridge in the valve. Partially plugged or something caught in it. If you're not sure the make or model of the faucet.... a picture could help.
How-to-insert-pictures
Older faucet ?
Where are you located? In North America most faucets, even those with separate hot and cold knobs, have a single spout. In the UK totally separate hot and cold faucets are common and you might have a clog in the hot water one.
