How to stop leak - poly fitting to pool pump.
Old 06-07-18, 11:29 AM
T
My pool pump has started dripping from the joint of the plastic pump housing (discharge side) and the gray plastic screw-in fitting that connects to a poly pipe.
I disassembled it, inspected for cracking, etc. then re-wrapped with tape, but the leak persists.
Suggestions?
Old 06-07-18, 05:32 PM
Received 4,089 Upvotes on 3,672 Posts
Tape probably won't cut it as it's under pressure.
Can you post a picture of that for us..... How-to-insert-pictures
