Long washer drain pipe?
Old 06-08-18, 05:36 PM
maarkr's Avatar
Received 12 Votes on 10 Posts
Can I install a drain pipe to connect a moved washer to an older basement washer drain 30 feet away? If the slope is 1/4" per foot then that's 7.5", so that doesn't sound bad.
Old 06-08-18, 05:43 PM
P
Received 858 Votes on 791 Posts
You will also need a vent.
Old 06-08-18, 08:41 PM
Received 1,476 Votes on 1,364 Posts
You'll also need, I believe, at least a 2" line to handle the amount of water without backing up.
Old 06-10-18, 03:21 AM
maarkr's Avatar
so if it's going to a previously installed and vented drain, I shouldn't need another vent near the washer?
Old 06-10-18, 05:33 AM
P
Re-read post #2. You need a vent.
Old 06-10-18, 06:30 PM
Z
Received 188 Votes on 168 Posts
For a 2" drain, the max distance from the trap to the vent is 60" (5').
For a 1.5" drain, the max distance is 42" (3.5')
Your locale may allow the use of AAVs (Studor vents) so it may provide a good way to vent.
