What year(s) did we convert to PVC?
Old 07-05-18, 06:03 AM
SJMaye's Avatar
Received 1 Upvote on 1 Post
I am considering purchasing a home built in 1976. I have not seen it yet. One thing came to mind that could be a problem is if it has cast iron piping. Does someone here know when plumbers switched from cast iron to PVC?
Old 07-05-18, 06:45 AM
V
Received 3 Upvotes on 3 Posts
At least it isn't outfitted with Orangeburg Pipe, whose production was finally discontinued in 1972.
Old 07-05-18, 06:47 AM
SJMaye's Avatar
Thanks, Vermont. I had never heard of that before. After looking it up, I am glad there is no chance of that being in that home.
Old 07-05-18, 07:15 AM
V
Originally Posted by SJMaye
". . . I had never heard of that before. After looking it up, I am glad there is no chance of that being in that home . . ."
Yes, they even used Orangeburg for drainage in the Empire State Building back in the 1930s . . . . which was fine until minor clogs created pressures which could not be tolerated by the Orangeburg. History says that a good time was had by all !
Old 07-05-18, 07:21 AM
SJMaye's Avatar
Old ways not always better...
Old 07-05-18, 09:33 AM
P
Received 2,121 Upvotes on 1,899 Posts
Cast iron is not a bad thing. It is still used in many higher end homes as it's quiet. You don't hear water pouring down inside the wall when someone upstairs flushes a toilet. And Cast iron is surprising resistant to rusting so it can have a very long life. If undisturbed it's joints can remain watertight for decades. For me the big thing to look out for is galvanized steel drain piping which usually has threaded fittings joining it together. It is much more prone to rusting out on the bottom side. Once you spot a little leak don't think about patching the leak rather start replacing pipe. Steel water supply pipes also have a rusting problem though it can occur anywhere and in my area copper water lines aren't much better.
Old 07-06-18, 01:17 AM
steve_gro's Avatar
I still haven't made the switch. Cast iron, aside from being a little heavy, is a good job. Much quieter than plastic.
Old 07-06-18, 05:31 AM
XSleeper's Avatar
Received 1,900 Upvotes on 1,706 Posts
Dad built a house in 1972 and used pvc for everything. So it was commonly used then. But some municipalities didn't allow it for various amounts of time. (Old school... as mentioned, the old ways are usually superior).
Old 07-06-18, 06:23 AM
SJMaye's Avatar
Interesting. I read many complaints about galvanized and in my head wrongly lumped cast iron with it.
Any idea what years galvanized was used?
Old 07-06-18, 02:39 PM
steve_gro's Avatar
{from https://en.wikipedia.org/wiki/Galvanization}
"In the early 20th century, galvanized piping replaced previously-used cast iron and lead in cold-water plumbing."
It gets a bad rap because there's a lot of rotten galvanized piping still in use. Considering how long it's lasted, I don't thing it owes an explanation. Hot water galvanized will fail before the cold, so sometimes you'll see a place with copper hot piping and cold still galvanized.
Old 07-08-18, 07:31 PM
Z
Received 416 Upvotes on 369 Posts
In a 1972 house, there will be older mechanicals... eventually, they will need to be upgraded at some point if they haven't already. None of them should be too scary or dissuade you from the house.
A good inspector should be able to walk you through the house and help identify any systems that will need upgrades in the coming years. One of the issues of older houses. But new houses aren't always perfect either!
Old 07-08-18, 08:30 PM
Tolyn Ironhand's Avatar
Received 868 Upvotes on 731 Posts
My house is 1978 and is all PVC.
Old 07-09-18, 09:05 AM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
It's all about local codes. Many houses had DWV piping entirely piped with ABS or PVC plastic pipe since the late '60s, but I also have seen areas that still required cast iron under a basement floor through the late '70s. ABS was quite popular in my area in the '70s, but today ABS pipe and fittings cannot even be found, everything is PVC while ABS is the standard in other areas.
Old 07-29-18, 01:06 AM
steve_gro's Avatar
ABS is popular in my Northern CA area. I've always thought it's simpler to use ABS over PVC -- no priming. Just glue it together.
