How to add a refrigerator water line to existing CPVC water line?
Old 07-09-18, 08:38 PM
R
Question How to add a refrigerator water line to existing CPVC water line?
Hello, I want add a refrigerator with ice maker to my basement. I need to install a water line to my current CPVC pipes. The location I want to install this is about 10' from the main inlet line into the house. My house / CPVC is about 17 years old. I've read not to use a saddle, so can you offer any suggestions for the safest and most reliable way to install this? Thanks. - Rick
Old 07-09-18, 10:10 PM
Received 2,978 Votes on 2,686 Posts
Although it's not the least expensive way to go..... A SharkBite fitting will make the job fairly easy.
SharkBite-24985A-Service-Compression-Connection-for-Icemaker
Old 07-09-18, 11:59 PM
steve_gro's Avatar
Received 1 Vote on 1 Post
Is that a gas line without a valve in the image?
Old 07-10-18, 01:20 AM
Marq1's Avatar
Received 953 Votes on 865 Posts
Install a T, run it to the desired location and yes a valve should be installed on the end of the water line also!
Old 07-10-18, 04:10 PM
R
PJmax, I researched your advise on the Sharkbite and that looks like the right solution. Thank you!
One thing though, I've read about CPVC becoming brittle. Mine is between 15-20 years old. Should I be concerned about mine splitting or cracking when I try to cut it? I'll be using a ratcheting PVC cutter.
Steve_gro, yes that's a natural gas line with no valve. I'm not familiar with plumbing codes, so not sure if that's a no go, but I noticed I have them in multiple locations.
Old 07-11-18, 10:03 AM
Z
Received 320 Votes on 286 Posts
I think you'll be fine with a ratcheting cutter. Go slow and it should cut fine.
If you're worried, you could use a fine-toothed sawzall, but I'd be more worried that you'll end up shaking the pipe and cracking it that way.
The yellow-coated gas pipe looks like CSST, so there's likely (hopefully) a valve on the other end before it connects to the appliance. But that's probably another project/thread.
Old 07-11-18, 11:45 AM
R
Zorfdt, Great answer. Thank you!
As for the gas lines, they do all have valves on the other ends.
