Utility sink faucet replacement
Hello everyone,
My current utility sink is 2 3/4" on center galvanized steel faucet that is leaking really bad. I have a 3 1/2" copper faucet and I am wondering if there is a way to use this faucet and connect it to my current plumbing set up? Is there some type of spacer that I can buy to fit the 2 3/4" spacing to the 3 1/2" spacing on the new faucet? I am looking for recommendations or suggestions?
Thanks in advance!
Thanks in advance!
It looks like the left hand pipe is leaning in towards the right pipe and making the gap look smaller.
Can you push the left hand pipe a little to the left ?
Thanks for the reply, Pete. Unfortunately, it's just the way I took the picture since I was trying to hold the new faucet at the same time. The pipes going down are rather straight.
The problem is to extend it a bit you'd need a coupler and a close nipple which would be too long.
What you can do is to measure that pipe back to its connection point and replace it with a 1" longer piece.
I'd go with Audioslave22's idea. I'd remove a few of those nipples and replace with a 1/2" FIP angle stop. Then flexible supply lines to connect to the faucet.
Something like this:
Thanks for the ideas! Yeah, it is probably a good idea to get some turnoff valves installed either way. Right now I have to turn off all the water in the house to fix =/
