Locating ABS fitting
Old 11-03-18, 10:05 AM
I was looking online for an ABS
coupler ..1 inch slip male OD to 1/2 inch barb. The barb is going into a garden hose that I cut up.
I couldnt find one...any ideas??
Old 11-03-18, 04:03 PM
Received 1,104 Votes on 1,024 Posts
1" ABS OD ? Usually plumbing pipe is sized by the ID. 1" OD may be 3/4" pipe ?
Probably going to be a two piece setup.
Old 11-04-18, 05:27 AM
Z
Received 21 Votes on 21 Posts
If the pipe is plastic and you are measuring about a 1 O.D., then that would probably be 3/4 PVC pipe. 3/4 PVC has a 1.050 O.D. Im pretty sure the smallest ABS pipes are 1 1/4 nominal size and have a 1.66 O.D.
Old 11-04-18, 09:32 AM
Z
(Wait a minute!!! I thought on your 10-15-18 post it was resolved the pipe WAS NOT ABS??? Oh well here goes anyway -LOL)
You probably need more than one fitting as PJMax pointed out, and I think this is the kind of thing you could do with two fittings. If it is 3/4 PVC (if not just changes sizes of the fittings):
(spigot end means the end has the same O.D. as the pipe size, and hence will push into a coupling, in this case, push into the 1/2 end of the 3/4 x 1/2 reducing coupling. I’m sure there are other ways to do it.)
Old 11-06-18, 05:33 AM
Z
OK - my bad! That was someone else who posted about ABS on 10-15.
HTML code is On
