Under sink leak from supply line.. how do I fix??
Old 01-11-19, 05:07 AM
T
The pipe is leaking and the sink is not being used. I've noticed an increase in the water bill and this is the reason..
Old 01-11-19, 06:18 AM
Received 129 Upvotes on 114 Posts
I small drip is not the likely cause of the increase.
Why not just replace the line with a new SS braided line?
Where all going to have to guess what's causing the leak without a picture.
Old 01-11-19, 06:27 AM
W
Received 66 Upvotes on 57 Posts
Is the leak before or after the shut-off valve?
Old 01-11-19, 07:30 AM
P
Received 2,270 Upvotes on 2,022 Posts
You only said "the pipe is leaking". There are several different pipes under a sink. Which pipe? Where exactly is the leak?
