Kraus Sink - Basket Strainer Installation Question
Old 01-19-19, 05:47 AM
L
I'm installing a new stainless steel, deep bowl sink made by Kraus. The sink strainer instructions suggest installing the metal drain piece, then a foam ring over the sink. Underneath, there is another rubber gasket with grooves and then the plastic drain piece. The assembly is held together with a screw on top.
Nowhere do the instructions mention plumbers putty. I'm assuming it's not needed with the foam gasket?
Thoughts?
I've attached pic of parts.
Old 01-19-19, 11:40 AM
Z
I would assume the foam ring is in place of the plumber's putty. I haven't installed one like that... but I would follow the manufacturer's instructions.
Worst case would be you'd need to re-install with plumbers putty.
Old 01-19-19, 12:13 PM
Norm201's Avatar
Yes, the foam gasket takes the place of the putty. But personally I would prefer the plumbers putty.
Old 02-02-19, 07:35 AM
L
Thanks guys- another quick question.... there is a slotted screw that holds the basket down (see pic). There wasnít a special tool included and I canít seem to find an extra wide flat head screw driver for this (approx 3/4Ē). Is there another tool I should be using? Anyone know where 8 can get a flat screw driver with a wider head?
Old 02-02-19, 01:18 PM
airmark's Avatar
Wink
The tip of a common automotive type pry bar will have a extra wide flat tip. Any length pry bar from 8" to 24" will do.
