High -pitched Squeak
I have an under-slab CPVC water line system. A single run with several branches. In my master bath, I get a high pitched squeak when I operate a water valve at any other location. It's not particularly loud, but it happens every time another water valve is operated. Any ideas ??
Is the squeak coming from a faucet? If so it might be a balancing spool in the faucet moving in response to the changing water pressure. If it's not a faucet making the noise maybe the pipes are moving slightly and rubbing against something.
