Leak at base of main waste PVC pipe on basement concrete floor!!
Old 08-06-19, 11:59 AM
L
Hello all, I have a small leak at the base of my main waste PVC pipe in my basement on the concrete slab. How do I fix this without breaking the concrete up? Will plumbers putty work? It's a small leak, maybe a small puddle in 6 hours time about the size of a frisbee. Any help will do. The PVC pipe is black 3 inch PVC. Thanks!
Old 08-06-19, 04:44 PM
P
Received 684 Votes on 631 Posts
Where specifically is the leak? A puddle on the floor doesn't tell us where the leak is located.
If the pipe is black it is ABS not PVC and will require a ABS or universal glue approved for use on ABS plastic.
Old 08-13-19, 11:45 AM
Z
Received 131 Votes on 121 Posts
A picture and location of the actual leak would definitely help.
You can try something like JB Weld as a potential solution. It's an epoxy putty that might be able to seal the leak. It's not a 'guaranteed' solution, but is probably worth the $5 and 30 minutes it'll take to try it out. If it works, great! If not, then we can look at replacement.
HTML code is On
