Bypass configuration question
I'm planning on installing a water filter along with a new water softener.
Should I create a separate bypass circuit for the water filter, or use the same bypass circuit as the water softener?
I've attached pictures showing both configurations. Just curious what's the best way to proceed.
My goals is to minimize the amount of fittings (in order to not restrict water flow).
Thanks!
First picture showing filter and softener in same circuit.
Second picture showing two separate bypass circuits (also includes two filters, I'll only have one on mine)
Thanks!
A good reason for a separate bypass circuit for the water filter is so you can bypass either one in case of a fault or servicing.
If you have one bypass loop and the softener needs service..... the filter needs to be bypassed too.
I don't think it much matters. The number of times you'll have to bypass either of them will be minimal at most.
I'm a bit OCD, so I'd probably have bypasses for each. Either way, the few extra fittings won't noticeably affect the pressure.
