Does Pex pipe freeze?
Need to replace some damaged copper pipe ( 1/2" ). I will use Pex. Don't want to demo siding and sheeting, but guess I have to. Will insulate pipe and use Pex.
Thank you, Charlie.
Thank you, Charlie.
I'm glad someone else handled the obvious already. Yes, water below 32f can freeze.
PEX tubing is highly resistant to damage if the water inside freezes. The plastic naturally stretches with the expanding ice without damage. The thing to watch out for is fittings and your fixtures. PEX fittings and your faucets can not handle freezing water and they can crack or burst if the water inside freezes.
Zorfdt voted this post useful.
you could also abandon the old line and route your new pex lines through an interior wall if you're going through all that trouble. It's a bit like fishing really thick cable, but they are flexible enough to fish through a wall.
