Looking to remove an old gas cooktop and replace with a gas range.
The shut-off valve has no handle on it, just a square "bolt-head".
Are these still good to use or do they need to be replaced?
If it needs replacing, I would not do it myself, but if I keep it, then I would do the removal and installation of appliances myself.
I assume to close the valve I would just turn the square 1/4 turn clockwise? Then replace flex-hose (hoping that the connector kit has the needed addaptors for this fitting).
Here is a picture of the valve:
I will also remove a gas wall oven. It has the same type of valve and here is a picture of that one:
This one will be removed and not replaced, since we are getting a range in place of the cooktop.
So, here I would just close it with a 1/4 turn and then simply remove the hose. Is the valve in shut position considered enough of an end cap or does it need an aditional cap?
If working in the area I'd be tempted to replace those shutoffs with modern quarter turn ball valves. In an emergency it's nice to have a valve with a handle you can just reach down and close without having to find the key or a wrench.
I looked into these valves a bit more. It seems they need to be "re-greased" every 5 or 10 years? I really doubt that this has been done in my house and I also don't want to regrease them in 5 years.
I guess the square knob is turned 1/4 turn, but there is an allen wrench hole on the other side, that unlocks it for turning. Seems dicey. But nevermind.
These will be replaced! I also realized we have the same valve on our gas tumble dryer downstairs, so someone could come and update all three!
The water utility wants to change the meter and I need to replace the 60 yrs old shutoff valve.
Is the old valve a compression valve?
What kind of valve would be the easiest to install?
The pipes are 5/8 [ 3/4 outside diameter ]
The visible thread on the valve 1'' diameter, the nut 1 3/8'' and the fitting 1 1/8''.
Thank you
[img]https://cimg7.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1333/dsc00854_045ce45aea2acc964774405a860bbbba270f3705.jpg[/img]
Read More
Hi all,
I am working to convert a bathroom from a vanity to a pedestal sink.
The old drain line came out of the wall on the left edge and ran along the wall and entered the vanity from the side. You can see in the picture on the left where they had used a hole saw to get the drain out along the side.
I am trying to get the best way to have the drain centered under the water lines for the pedestal sink. The picture show a test fit for what I am looking to do. The issue is there is not much room to work with since the ductwork is in the way. This initial solution would have the drain come out of the wall at an angle though. I guess another way would be to have the drain line come out perpendicualar then 90 degree turn to run along the wall and then 90 degree to fit to the pedestal sink but then the whole drain line would be visible outside the drywall.
Any advice or suggestions? Is the angled method I am test fitting in the pictures ok to do? Thanks!
[img]https://cimg6.ibsrv.net/gimg/www.doityourselft.com-vbulletin/800x600/drain1_bb2d0ef7c02b0f69d5fc0dea98629de1c02b1d23.jpg[/img]
[img]https://cimg8.ibsrv.net/gimg/www.doityourselft.com-vbulletin/800x600/drain2_504388fb86e1743d91c1f8cc8c798d0ee8229095.jpg[/img]Read More
