Prevent Water from House from Draining.
Old 07-26-23, 06:31 PM
A
I am replacing my Water Pressure Regulator. The meter is 30 inches lower than where it goes into the house and about 80 feet to the meter and 16 inches deep. When I cut the PVC pipe at the old regulator is the water from the house line going to fill up the hole (18x18x16 inches), I dug. Planning to leave all the other faucets closed. Hoping it would work like a straw with your thumb over the end with all the faucets closed. I estimate it would be about 6-7 gallons.
Old 07-27-23, 05:04 AM
P
Received 2,180 Upvotes on 1,950 Posts
Yes, the water will drain and fill the hole. Most common would be to bail out the water but you can check the rental stores in your area for a pipe freezing kit. It clamps over the pipe and it freezes the water in the pipe forming a plug. Then you can cut the pipe and work without the water coming out. You can also do the same with dry ice. But, that whole freezing process takes about 1/2 an hour and is expensive so almost nobody does it.
Old 07-27-23, 06:52 AM
2
Received 389 Upvotes on 338 Posts
If you have a shut off valve inside where the pipe enters the house, closing it will prevent house water from flowing back into the pit.
Old 07-27-23, 10:34 AM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
pipe freezing kit.
​​​​​​​When I cut the PVC pipe
​​​​​​​Can that be done with PVC?
Old 07-27-23, 01:26 PM
P
Freezing works as long as both ends of the pipe are "open" to accept the pressure of the expanding ice. If it's near a closed valve the pipe has a good chance of bursting. The key is to not freeze too large an area and give the pressure somewhere to go.
Old 07-31-23, 08:22 AM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
Is this a Pressure Reducing Valve? Are you locating it outside at the meter and underground?
