Polyethylene gas line size
Old 09-25-23, 01:31 PM
W
Hello all! Love this site. First time posting. I am going to be installing a magic pak unit and also a hot dawg heater. 60K BTU Hot dawg for the garage and 30K BTU for the magic pak that will heat the porch on other side of the wall. The Gas line I will be burying from the other side of the house and will run approx 170 feet to the garage. Can I get by with 3/4 inch polyethylene or would I need 1 inch?
Thanks in advance
Top Answer
09-25-23, 04:54 PM
PJmax
PJmax is offline
Received 4,155 Upvotes on 3,731 Posts
Welcome to the forums.
Underground yellow IPS poly would be a good choice.
Poly gas line is rated to be used as buried only. Be sure to get pipe risers for each end.
You need 60k + 30k = 90k delivery
Changed reply to reflect natural gas over LPG.
Natural gas is much lower pressure which requires a larger pipe size. 3.5 wc vs 11 wc
5' of pipe gets added on for each additional fitting like a 90.
The chart is showing that 1" will be borderline.
Old 09-25-23, 04:54 PM
Whodoyou, Zorfdt voted this post useful.
Old 09-25-23, 06:02 PM
W
Using Natural gas
Thank you so much for your quick reply. I forgot to mention we are using natural gas. Would that make a difference in comparison to liquid propane?
Old 09-25-23, 06:20 PM
Sorry. Don't know where I got LPG from. Modified my original post.
Old 09-26-23, 08:07 AM
W
Thanks again Pete. Very much appreciate you!
Dan
