Can this be used to solder copper pipe fittings?
Old 04-09-24, 11:22 AM
Will one of these small torches work for soldering residential 1/2" copper pipe and fittings?
Bernzomatic Soldering Propane Torch Kit (14.1-oz)
Old 04-09-24, 11:32 AM
P
Received 2,309 Upvotes on 2,054 Posts
Yep, that's what thousands of plumbers use.
And if you ever start doing things where the torch doesn't produce enough heat you can switch to MAPP gas. It's more expensive but it burns hotter. Not needed for sweating the 1/2" piping you mentioned. Propane works just fine for that.
millworker301 voted this post useful.
Old 04-09-24, 11:33 AM
Received 4,140 Upvotes on 3,718 Posts
Yes.... that will work fine for smaller copper fittings.
