Using 6gal ShopVac to empty 250gal fishpond
Old 03-27-16, 12:17 PM
O
Each Spring we empty our 250gal fishpond with our 6gal ShopVac (mod 87708-07). It is a tedious challenge since there is no drain port to continuously drain. Is there a way to create one without damaging the Vac? We've tried using a hose draining system with our drill but the drill (2) batteries don't last long enough to drain the entire pond in one session.
Old 03-27-16, 12:27 PM
Received 1,316 Votes on 1,216 Posts
Why wouldn't you just buy/use a small 120v pump ?
One designed for a pool cover would be ideal. They start around $30.
A ShopVac wasn't designed to move a lot of water. It was designed to remove residual water from the floor.
Old 03-27-16, 12:38 PM
W
Received 22 Votes on 21 Posts
Pond
You could siphon the water out of the pond if you have a nearby area with grade level lower than the bottom of the pond.
Old 03-27-16, 12:40 PM
Norm201's Avatar
Received 287 Votes on 257 Posts
A small 1/6 hp utility pump would be ideal for this application.
Old 04-13-16, 02:00 PM
C
Received 119 Votes on 94 Posts
For $20 you can get a 12vdc 500GPH bilge pump. Just hook it up to a battery.
