Pond Pump Circulation
Hey all, looking for some experience and head knowledge in regards to creating circulation from a large (1 million gallon) pond to a smaller (25,000 gallon) pond that is seated next to the large pond at a higher elevation. The smaller pond is set up to, and does, overflow into the larger pond with rainfall. Any insight, concerns, suggestions are welcome.
Welcome to the forums.
A pretty vague question. You want to pump water from the larger pond up to the smaller pond ?
A million gallons is nothing to sneeze at.
How much water....... in gallons ?
How many gallons per hour ?
How high is the lift..... in feet ?
What do you have available for power..... 120/240/277/480 .... single or three phase ?
You did not say or specify any goals so it all depends on how much water you want to move. Almost any pump can move water from one to the other.
