Hayward 1.5 hp pool motor rebuild?
Old 08-30-17, 08:08 AM
A
Good morning. Thanks in advance for any info you can provide.
Have a 7 year old Heyward pump in a covered pool house near pool. The original outdoor outlet fried middle of last summer and I installed a new outdoor outlet/cover/etc.
Since then, when I turn the pump on (at the breaker in the garage each morning), the breaker trips, then I turn on again, and good for all day pump/filter running. Each morning same thing.
I replaced breaker and still trips making me think not breaker. Voltage to outlet looks good making me think outlet good.
I am thinking the pump motor got adversely effected when the outlet blew and surged, causing more draw upon initial start and that line to trip since?
I heard these can be rebuilt? Who would do something like that in the area? Or would Heyward?
Best, AW
Old 08-30-17, 08:40 AM
I don't know if rebuilding is the answer. What fried the outlet in the first place?
Old 08-30-17, 08:43 AM
T
Received 4 Upvotes on 4 Posts
Do a search on starting Capacitors replacement for your specific motor. This assumes that there is no bind in the motor.
Old 08-30-17, 08:47 AM
A
Age. It was original from the early 60's. It failed Summer 2016.
New outlet and line professionally verified. Breaker replaced new.
Who rebuilds those motors usually?
Old 08-30-17, 10:12 AM
P
Received 2,116 Upvotes on 1,895 Posts
Motor repair shops. Generally it's done for industrial or more expensive motors. For most motors found around the home it's cheaper to simply replace it.
Old 08-30-17, 10:54 AM
Received 3,897 Upvotes on 3,494 Posts
I agree.... replace the motor.
Is that a regular breaker or GFI breaker ?
