Pentair Quad 60 DE filter
Old 09-08-17, 10:05 PM
B
afterbcleaning and replacing de my filter runs fine for about 2 weeks then the psi goes up and the crawler stops moving. I generally run at 1800 speed. Any idea?
Old 09-08-17, 10:32 PM
Received 3,898 Upvotes on 3,494 Posts
Usually when the pressure rises it means it's time for the filter to be backwashed.
Old 09-09-17, 05:11 PM
B
Thanks for the reply. I'm having issue with backwashing this. I don't see a backwash option in my control panel. I opened the bottom of the filter and let the water out and ran the pump for a minute but it didn't fix the pressure. Any suggestion?
Old 09-09-17, 05:51 PM
The quad 60 DE is just the filter part of the system. You need a 5-6 way valve to direct water thru the filter and system. It's this valve that has backwash on it. It directs the water thru the filter in the opposite direction.
Old 09-10-17, 07:19 AM
B
I'm recently moved into this house, so not much experience yet with this filter. Here is a pic of my system if you have any pointers. No idea why image isn't loading...
https:/
/ibb.
co/jwOWBv
Old 09-10-17, 10:29 AM
ibb. co is currently blocked from the DIY site due to ransomeware found in pictures they were hosting. Attach the picture directly to the board. Use the attach instructions in the red box.
http://www.doityourself.com/forum/el...-pictures.html
Old 09-10-17, 03:46 PM
B
Awesome thanks. Here it is
Old 09-10-17, 05:42 PM
Simple and Easy Cleaning
Cleaning the Quad D.E. filter couldn’t be easier. You have three options: backwash and recharge like a traditional D.E. filter, remove and rinse off the cartridges, or simply remove the lid, leave the cartridges in place, open the drain plug and rinse.
Since you don't have a backwash valve installed you will need to clean the filter manually.
This is a link to your filter manual...
pentair pool/downloads/filters/quad de owners manual english.pdf
Old 09-10-17, 07:28 PM
B
Damn that's what I thought. It's kind of crappy because it requires so much de and takes a while to manually clean. Well thanks for the help. It seems 2 weeks is usually when it needs to be changed. Is that consistent in your experience?
Old 09-10-17, 08:28 PM
Based on what's in the water and the amount of "stuff" that falls in.... that would be about right.
