Pool chemicals
Old 06-12-19, 11:33 AM
Pool chemicals
i just cleaned and filled my 16000 gallon in ground pool. Id like to know what chemicals I need to add to this fresh water right away. Many thanks
Old 06-12-19, 11:38 AM
Received 4,055 Upvotes on 3,638 Posts
I add a mineral reducer like LessIron to remove metals from the freshly added city water.
Then I add algaecide and a minimal amount of chlorine.
You should take a sample of your pool water to a local pool store for analysis.
They can recommend what needs to be added. It's different in different areas.
Old 06-12-19, 12:19 PM
Received 860 Upvotes on 752 Posts
It's been awhile since I had a pool but I remember the algaecide and chlorine being the most important. I also had to shock the pool every month [or was it every week?] Pool stores used to analyze a sample of your pool water for free, I assume they still do.
Old 06-12-19, 12:31 PM
Most pool stores will analyze for free. You need to be careful and take what they say with a grain of salt as the test is free and they make money by selling you many different chemicals.
Old 06-12-19, 12:34 PM
Ya, early on I took a sample to the pool store every month and bought what they recommended. Then I noticed how much cheaper similar products were at places like walmart. After the 1st yr I all but quit going to the pool store. By then you should know how to take care of your pool but they are there if you run into problems.
Old 06-12-19, 02:07 PM
Thanks guys ! You rock ! I agree regarding the pool supply stores. They will give free water analysis then kill you with selling you stuff ! I think a good testing kit will be my best friend. Aah this water looks so good now ! I should do my best to keep it up !
Old 06-12-19, 05:51 PM
You definitely need a chlorine/PH test kit. The other parameters need to be checked professionally.
