Why are biscuit tables traditionally made of marble?
Old 01-13-23, 09:40 PM
R
Received 3 Upvotes on 2 Posts
Anyone know why these old biscuit-making tables are made of marble? If you wanted to make one is there a reason it couldn't be made of wood with laminate to facilitate cleanup and prevent bacteria from being trapped?
Maybe the weight is a factor, to keep the table stable and in place?
Old 01-14-23, 03:35 AM
Received 293 Upvotes on 263 Posts
I think it is because it tends to stay cool so you are not softening/melting the butter/shortening in the dough.
RobertP voted this post useful.
Old 01-14-23, 05:01 AM
P
Received 2,118 Upvotes on 1,897 Posts
Yes, I also believe it's for the temperature. If you ever see fudge being made in a shop they usually work on a heavy stone slab.
Old 01-14-23, 08:21 AM
2
Received 387 Upvotes on 337 Posts
As others have stated, temperature is the reason. A good DIY alternative is Corian or similar synthetic countertop material. It can be pre-cooled with ice packs but even that is not necessary if the counter is not in a too warm place.
Old 01-15-23, 06:30 AM
H
Received 283 Upvotes on 243 Posts
Agreed that stone stays cooler and keeps the dough cold, ALSO because stone is non-porous and easy to clean up.
We've got two antique rolling pins, one is wooden with deep grooves & holes- I think for pounding-down a risen dough, while the second is actually made of marble, for cookies, pie crusts and other very buttery doughs.
2john02458, RobertP voted this post useful.
