How to absorb moisture in bucket of wheat berries?
Old 05-19-24, 12:48 PM
Preferably for free. Til I figure something out I suppose those little silicone packages will help but I've got a about 30lbs in a bucket and I'm in SWFL so it's a little more moist around here and I don't have AC. Any ideas? I've got activated charcoal. Would that work if I put it in a cup upright and sit it on top?
Old 05-19-24, 01:18 PM
P
Received 2,261 Upvotes on 2,014 Posts
Freshly opened or recharged desiccant packets would be the best option. For something free I'd bake some dry ride on 300 for 15 minutes to drive off as much moisture as possible. Then put the super dry rice into fine mesh or cloth bags and into your wheat.
I don't think the activated charcoal will absorb much moisture.
Old 05-19-24, 03:08 PM
Thanks Pilot Dane and those packs are pretty cheap at $9/60. But I'll try the baked rice trick too
Old 05-19-24, 03:11 PM
XSleeper's Avatar
Received 1,958 Upvotes on 1,755 Posts
You could run them through a dehydrator... or a popcorn air popper. Just long enough to bring the moisture down. Or spread them out on a baking sheet and warm them in an oven on low for a while. Keep the door open to let the humidity out.
Old 05-19-24, 05:36 PM
XSleeper I need a long term solution. Not something tedious I have to do periodically
Old 05-20-24, 09:36 AM
W
Received 6 Upvotes on 4 Posts
For a few $$'s you can get desiccant and make your own drying packs. Or you could get the silica gel packets specifically for use with food.
Old 05-20-24, 03:11 PM
Whittsend i will do this if I don't try the baked rice method suggested earlier. Thanks
