Disable privacy door lock?
Old 02-15-18, 07:50 PM
Q
Received 1 Upvote on 1 Post
I have a privacy door with one of those built in switch locks that you turn right to lock, left to undo.
I actually have it on an outside door but want to disable the switch as there's no key on the other side and anyone could accidentally lock themselves out.
Is there a way to disable it in the open position? I have a deadlock above that does the actual locking/security.
Old 02-16-18, 03:04 AM
pugsl's Avatar
Received 78 Upvotes on 71 Posts
Replace it with a bedroom door knob. Here is one 3rd in.
https://www.lowes.com/search?searchTerm=door+knobs
May be wrong I seem to remember some have a rod in center that will come out. been a few years since I took a knob off.
Old 02-16-18, 04:26 AM
Q
I was trying not to replace it
Old 02-16-18, 05:58 AM
V
Received 3 Upvotes on 3 Posts
They usually come with a tine flat screw-driver type tool which can be inserted through a tiny hole in the outside knob to unlock them.
I have one such tool here; unfortunately, I store it inside the Medicine Cabinet of the same Bath, so if someone ever got locked in, they'd have the Key in there with them.
You could use a small (very small) flat screw-driver to un-lock it; but I've never had that problem since installing that Bath 25 years ago.
