Installing Schlage Electronic Deadbolt - Double Cylinder Deadbolt in the way
Old 02-22-18, 11:06 AM
C
My sister bought a Schlage electronic deadbolt for her new condo. Above her regular deadbolt, there is a double cylinder deadbolt. This prevents the battery compartment from sitting flush against the door. She has no issue with me removing the double cylinder deadbolt, but I don't know how to get rid of the hole. I was thinking about getting a deadbolt cover. They're not great looking by any means, but I thought that it would be a possibility. I think the cover is ~1/16" inch. That would make the deadbolt not sit flush at the top. The only solution I can think of is cutting it somehow. Then the issue becomes removing the battery compartment. Has anyone else had a similar problem? Any recommendations for getting this to work?
https://www.amazon.com/dp/B00D2K366U...ing=UTF8&psc=1
Old 02-22-18, 12:48 PM
Received 1,248 Upvotes on 1,192 Posts
First thing I would do is check with the condo association to make sure you don't violate one of their rules in the process.
Is there any way to actually fix/plug the door? Of what material is the door made?
Old 02-22-18, 01:36 PM
pugsl's Avatar
Received 77 Upvotes on 70 Posts
Why not take double out and put electronic in there. Leave other one in door you don't have to use it.
Old 02-22-18, 02:42 PM
C
Good suggestion! How did I not think of that? I'm wondering if it may look odd with the keypad being so high. I'll have to check when I'm there.
