Fastening Pergola waterproof sail
Old 09-10-16, 01:30 AM
Hi,
I have built a pergola against my house. I am installing a waterproof sail across the top and was wondering if there is a transition material available to fix to the house and the top of the sail to prevent water falling down the void. I am assuming there must be a 90 degree angle that would do this, just not having any luck finding it!
Any help would be appreciated.
Thanks
Old 09-10-16, 04:36 AM
P
Received 2,323 Upvotes on 2,066 Posts
That is not a common construction method especially for a small residential project. What does the sail manufacturer have available for mounting? What I have seen is a cable or rope is sewn into a edge then that edge slides into a "C" shaped slot in an aluminum extrusion.
Old 09-10-16, 05:23 AM
Received 129 Upvotes on 114 Posts
Got a picture of what you've built so we can see what your seeing?
