Gutter/ice dam heat rope idea
Received 0 Votes
So I know this post is kinda off-topic but I figure this would be the best place to see if anyone has input on these gutter heat ropes...
Winter is coming and I don't have a garage. I was going to attempt building a car port but with a newborn and October around the corner I doubt it's going to happen before this winter season.
So.... would the below idea work to keep the car windshields de-iced and snow free? Or do these heat ropes not put out enough radiant heat? We're talking about a windshield, so... 36"x60" approximate area?
Just drive in until rope is on windshield and in the morning, back out and give the wipers a go.
An yes, I know... this is there genius or the WORST idea ever. But it's better than nothing this season right?!
It's always good to run your ideas by others.
Interesting idea BUT when the snow melts you're going to have a frozen block of ice.
Ice down the side of the car and stuck in the air dam.
I think a better and more economical idea is the cover as Paul says and/or treat the windshield with RAINEX. It works to keep the ice and snow from sticking. Also a spray bottle of 50/50 rubbing alcohol and water works great to thaw the ice to make easy scrapping. I've been using it for the past two seasons.
Received 0 Votes
Shoot. I knew it was too good to be true. Good call on the ice dam all down by the vent. Last season I used a large commercial floor door mat thrown over the windshield. It worked ok but was annoying. Trying to think of an easier solution.
