Removing downspout from rear of house ?
Old 07-23-18, 03:10 PM
W
Contractor recommended to remove/block downspout from rear of house. And have the other eavestrough angled towards the front of the house.
. (The reason I wanna do this to avoid water pooling at the back of the house because of the way the land is .)
Old 07-23-18, 05:19 PM
P
Received 1,621 Likes on 1,455 Posts
Ok, what is your question?
Old 07-23-18, 05:22 PM
W
1.Should I block the rear downspout and angel eavestrough
or
2. run a long downspout from back of the house to the front
For 1. my concern was too much water going to one downspout
Old 07-23-18, 05:34 PM
Marq1's Avatar
my concern was too much water going to one drain
What drain?
Old 07-23-18, 05:35 PM
W
By drain I meant downspout .
Old 07-23-18, 08:35 PM
Received 1,177 Likes on 1,135 Posts
This thread has gotten to be a mess, can you start over and provide some detail of what's going on to make you think action needs to be taken?
Old 07-23-18, 08:49 PM
W
I wanna re route the downspout from the rear of my house to the front.
I have 2 options
1. Run a long downspout from the rear of the house to the front
or
2. Block the rear downspout and have the water drain to the front downspout. (My concern here is that is it too much water going to one downspout ?)
Old 07-24-18, 05:23 AM
B
Please clarify. If you block the downspout from the rear gutter, how does water from rear gutter get to the front downspout? Can you re-slope the rear gutter and place the downspout on the other end?
Old 07-24-18, 06:16 AM
W
Yes the rear will be reslopped
Old 07-24-18, 09:56 AM
Marq1's Avatar
So if everything goes to the rear and you change it to go to the front you still have the same volume of water going down one down spout, how is that going to improve anything?
Old 07-24-18, 10:00 AM
W
I have 2 spouts currently. 1 front and 1 rear. I wanna route rear to goto front . (Becuase I dont want the water in the backyard . Plz dont me explain why )
so should I
1. Run a long downspout from the rear of the house to the front (with keeping the front drain obviously)
or
yes eavestough will be angled towards front of hi house drain
Old 07-24-18, 12:35 PM
Marq1's Avatar
So were finally getting the picture.
Installers dont install more downspouts than needed but it all depends on the length of the gutter and how much roof is supplying water but safe to say at some point it's probably going to overflow.
Might be easier to just work on installing some type of drain for the back yard to remove the water.
Old 07-24-18, 12:47 PM
W
Entire house only house 2 downspouts..
I ll just route the second Downspout to the front of the house. Creating a drain at the rear is more work.
Old 07-24-18, 06:02 PM
Marq1's Avatar
Thats debatable, considering the potential of consistently having the gutters overflowing onto the house and into the eves I dont see a lot of good coming out of this "improvement"!
Old 07-24-18, 06:09 PM
W
I ll re route the rear downpout along the wall and bring it to the front of the House..
Old 07-25-18, 06:30 AM
B
Have a separate vertical downspout in the front of the house for the downspout from the rear gutter. If looks are important , locate the downspout from the rear gutter on the end of the house less noticed.
