Ramp for channel drain system
Old 08-12-18, 10:53 AM
R
Received 1 Upvote on 1 Post
I have an L-shped channel drain system installed. One end has a hole for the water to drain into the ground, the other short end by the stairs isn't sloped enough though, so water collects at that point and doesn't make it around the corner to where it is sloped towards the drain.
Rather than drill a hole at the "starting" point as well, I wondered if installing a long ramp to help the water move a bit more out of that space would help. I have this NDS drain, but can't find a slope/ramp that they sell. Any suggestions for a solution are much appreciated.
Old 08-13-18, 03:35 AM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
I suppose you could cut some type of plastic to fit in the bottom and glue/caulk in place, however it will eventual fill up to the point that it starts flowing, not sure it's really going to gain much!
Old 08-13-18, 06:29 AM
XSleeper's Avatar
Received 1,900 Upvotes on 1,706 Posts
Pour just enough self leveling sealant into the gutter to level it, something like Loctite S20.
Old 08-14-18, 05:24 AM
B
Received 289 Upvotes on 257 Posts
You can make a slope in the gutter below the step using Bondo. Top of slope on right side must be higher than bottom of the gutter on the left side.
Old 08-16-18, 06:09 PM
R
Thanks!
Thanks for the suggestions!
