Roofing, OSB or Plywood
Gets to be about 110 here in summer, single digits in winter. Snow only an inch or two most years, ice is a real problem though. Should I use 1/2" osb or plywood (or 5/8? 3/4? 1 1/2??) on my new shed roof and the outside walls? Shed is 12x10 hideaway with a slant roof.
Plan to get the rafters up (still haven't penciled that one out yet), get the tar paper on the walls/roof, and shingle with heavies.
boy howdy that 3/4 stuff is heavy, but if that's normal i'll get it done. Plan on 16" joist spacing so i can run insulation in it without cutting. Do I need to space them 1/8" apart (the plywood) or is it fine to butt them up.
Thanks Dave
Thanks Dave
7/16" OSB is the norm around here for roof decking although some will step up to 5/8" OSB. Plywood is always better but OSB should be fine. What pitch will your roof be?
Yeah, 7/16" is standard minimum, you use h clips on the seams between rafters... and yes, 5/8 osb is way better. If you get 7/16, make sure it says it is rated for roofs... every once In a while you find some that specifically says it is for wall sheathing ONLY.
Everyone but plywood purists use osb nowadays. For best results, don't leave it exposed to the weather for long... get the felt and roof edging on asap.
I used 1/2" osb on the shed I built about 8 years ago and have had no problems at all, even though it gets up to 2 ft of snow setting on it for long periods of time. It's also a Salt Box type shed like pictured.
For our garden shed, I spaced the rafters 24" apart and used 2x6s, with a 3/4" sheathing.
For our goat shelter, I spaced the rafters 16" apart and used 2x4s, with 5/8" sheathing.
Personally, I would never use 1/2" sheathing for any roof.
If you are buying your sheathing at a traditional lumberyard, the person at the counter will be able to tell you what to use for your span. If you are shopping at a big box though, for example, you will find markings on APA approved products that tell you the allowable span. You will see two large numbers printed on it, something like 32/16, and, in this case, tells you that that sheathing is good for a 32” span as roof sheathing and 16” span for sub flooring.
